oil pan removal
IanS13
let me just say this was the bigest pain in the *** to removei had to jack up the motor and unbolt the sway bar to get it out, after i got it out i see that there was no gasket on there just some selicone no wonder my car leaked so much oil, well now i have changed the valve cover gasket and will put in a oil pan gasket after i weild in the fitting for thr return line.
sxseguy
Car: Makin' it go faster!
There is a cork composite gasket available from Felpro, but it will leak more quickly than a well laid bead of liquid gasket, for sure. Just make sure that you clean the oil pan flange and the pan rails on the motor REALLY well before you put stuff back together.
ROB240
Car: 240 & Heep
ditto on the silicone sealing perfectly, Ive done a couple of them now and they have lasted for at least a few years now with absolutely no leaks. the key is making sure both surfaces are completely clean and free of old gasket material, rust, or whatever other kinds of crap that can get in there.
WDRacing
I always use high temp RTV or the Black type for all my gaskets. Even used it on the oil pan gasket of a 740whp R33 GTR.
Take some brake cleaner and spray down both surfaces, then wipe it down with some alcohol. Apply a nice bead of sealent to the pan and install. I would use the sealent with or without the gasket by the way.
WD
IanS13
so you guys are saying that the rtv will last longer than the gasket, and how long is long. the rtv that was on there was silver and leaked bad. maybe they did not lay it well who knows.
WDRacing
If applied well to a clean surface it won't leaK...EVER.
boost infested
Car: cars, chicks, food, and .....
http://www.cardomain.com/memberpage/606259/7
its easy to take the pan off without removing the whole swaybar. use the one piece gasket and rtv it to the pan. no leaks.
