davidevo16v »
https://forums.nicoclub.com/davidevo16v-u74060.html
Tue Feb 03, 2009 7:24 am
Dear all, purchased my Q45 about 1 1/2 ago. It now has about 160,000 miles. My wife and I truly love this car. In the past 4-5 months, we've noticed that the oil was getting dirty pretty quicky. Had to change the oil about every 1000 miles. I suspected sludge breaking down and contaminating the oil. In a way, this was a good thing. We needed to replace both valve cover gaskets last weekend and to our horror, sludge had created a wall about 1/4 inch thick. I have never seen anything like it. My guess was the first owner probably changed the oil once a year if at all. Anyway, we tried to avoid loosening up all that sludge, but I believe some of it broke apart when we separated the valve cover. Make the long story short, I think the oil pump pick-up screen is clogged. I changed the oil and filter twice to flush out the scrap to no avail. When i run the engine, the valves just chatter like crazy. Not sure if I damage the main bearings, but we are going to pull the oil pan this weekend to clean it out. Since the pan is remove, we are also going to chisle and carve out as much of the hardened sludge as possible. At this point I really don't see another option. What else do you guys recommend I replace (oil pick-up tube, chain guide, etc....). Well, wish us luck.
