1991Hardbody »
https://forums.nicoclub.com/1991hardbody-u182264.html
Fri Jul 29, 2011 7:17 am
I'm not entirely sure if they are the same. I would say that if the pick-up tube has the shape you need and bolts line up, you can use it. Same with the oil pan, as long as they have similar bolt patterns it shouldn't be an issue. The shape of the pick-up isn't going to affect oil pressure (since you're not changing the pump), and the pan only has to fit the block (since all it actually does is hold oil). Basically, make sure everything fits and clears the way you need them to, and there shouldn't be any probs. Good luck in your efforts!
I'll check on a few part nums and reply if I find any issues!
