Oil pan question
KA13
Car: 1998 Frontier
The person I had working on my car screwed me over and now I'm refusing to let him touch it anymore and I had a question about a job he left unfinished. I finally found an oil pump and im putting it on. The question is, according to him the oil pan can't be removed without unbolting and lifting the engine so that it can be cleaned and a new gasket can be put on...is that true or was he just b/sing me? I really need to know because I'm tearing into it once I get back from vacation and need to know what I'm getting myself into. Thanks.
slipnfall
Car: '06 D40
What year 240sx? Either way, you will need to remove the crank pulley and lower front cover to get the pump off. The pump is attached to the front lower cover. I am 95% sure you can not remove the front cover without removing the pump pickup tube: you have to slide the cover forward off the crank and the pickup will certainly hit inside the pan.
Put the car on 4 jackstands. Loosen the middle two front swap bar supports, and swing it down and out of the way. Use a floor jack under the transmission bellhousing to lift the engine. Loosen the pan and reach in the front to loosen the two pickup tube bolts. I did not need to loosen my motor mounts to gain enough clearance(probably raised the engine a good 1.5-2"), but your mileage may vary. Once the tube is lose, pull the pan, then pull the front cover/pump.
Be very carefull tightening the two front oil pan bolts that attach it to the front cover: they strip very easily.
3dKa24
Car: 2000 altima SE
Ive done it to a my old Talon I just had to jack up the car pretty high have it on some Jack Stands and go to work Removing a few things. Should be a do-able job for your S13 , just have your Helms handy.In case you dont have an FSM heres a link to DL it.http://phatg20.net/modules.php...id=66
slipnfall
Car: '06 D40
PS - you will need to remove the engine/transmission gussets(braces that connect the block to the bellhousing) to gain access to the rear few oil pan bolts.
boznuttz
Car: MS13
you NEVER really need to replace the oil pan gasket, just make sure you tourque em down the right way
slydin'240
Car: 1993 240sx Coupe, 2003 Maxima SE
boznuttz wrote:you NEVER really need to replace the oil pan gasket, just make sure you tourque em down the right way
I'm going to have to disagree with you on this. Nissan uses liquid gasket for their oil pan and definetly needs replaced if removed.
Yes the motor needs lifted to clear the engine cradle. Good luck bro, keep us updated.
KA13
Car: 1998 Frontier
Alright thanks guys. Any ideas on how long it should take to do it? Its an 89' with the ka24de btw.
slipnfall
Car: '06 D40
First time, probably 4-5hrs at least.
KA13
Car: 1998 Frontier
Cool. I want to get it done as soon as possible which is why I'm getting all the info now so I'll have it all when I get home. Does anyone have a picture of the middle two front swap bar supports that slipnfall was talking about so I'll know what needs unbolting? It would help alot because the auto stores around me can't get any manuals for 240's.
KA13
Car: 1998 Frontier
...and are there any torque specs I should know or will it be one of those jobs that you just tighten the bolts till it feels right?
boznuttz
Car: MS13
i had hondas on my mind metal oil pan gaskets. replaced a few, lolz so to me for that one
slipnfall
Car: '06 D40
I've been holding off on saying it, but search: there are links to a free factory service manual online. Just search for 'FSM download'. It will have all the pictures you need along with torque spec's.
KA13
Car: 1998 Frontier
Cool. I just found an FSM thats link actually worked. I had already looked for one but the links never seemed to work and I had to go to there main page in order to get it, but I have it now. Thanks for all your help guys.
