oil pan problems
Tofudrift
Car: S13
I'm trying to change the oil pan gaskets but I've ran into some trouble. I can't get the dang thing off!! I've undone the motor mounts and jacked the engine from the transmission up as high as it would go but I still can't clear the pan!!
The next thing I see to do is either remove the cross member and fully remove the pan (which I dont want to do unless I have too), or scrape the old gasket off and install a new one along with some RTV as it is hanging 3-4 inches from the engine.
Anyone have any advice on what to do? Is removing the cross member pretty easy? Thanks for any input you guys can give me!
Modified by Tofudrift at 7:30 AM 6/10/2007
