oil pan paint
gumby
Car: '89 240sx sohc
ok stupid question time.
the oil pan had a broken tensioner floating around in it so the paint is scratched off in places. i know its gonna get sucked into the filter as it flakes, but is there anything i can do with it off short of repainting the whole thing?
p.s.
very happy i decided to redo the gasket cause the other one didnt seal due to a bent up flange.
navysnail
hmm, i wouldnt worry about it, because like you said, thats what the oil filter is there for
msaskin
Car: cars, computers, skiing, mountain biking
240kid wrote:hmm, i wouldnt worry about it, because like you said, thats what the oil filter is there for
Too bad the random shrapnel in the pan will most likely clog up the oil pickup and starve the motor of oil before the filter can do anything about it.
I'd suggest getting a can of aircraft paint stripper (meant for stripping aluminum) and spray down the pan. After you spray it on it'll foam up and then you can just spray w/ water and the paint will literally melt off.
~matt
gumby
Car: '89 240sx sohc
i thought about that but what do i do afterwards? leave it bare? theres really no way to paint it as far as i can tell.
the paint would only flake off in tiny bits so its not like itll clog it all at once. the shrapnel is all gone. but id rather not have anything floating around in there if i can help it.
msaskin
Leave it bare. The pan is aluminum (or steel?). It's not like the oil is going to corrode it or anything.
~matt
navysnail
do you really think the tensioner is gona scrape that much paint off, and even if it did, it would come off in small flakes, not like big pieces
gumby
Car: '89 240sx sohc
id have to guess its some sort of alloy since it rusts on the outside. same with the water neck cast into the aluminum intake manifold, yet it rusts. go figure.
navysnail
well, you definatly need to get that tensioner out, but as for paint, i dont see the inside of the oil pan which is always covered in oil rusting, same reason why internal engine parts dont rust
gumby
Car: '89 240sx sohc
id have to agree with that
so why the hell did they paint it in the first place?
