You might as well since you got the transmission pulled alreadynewdude1 wrote:well the FSM basically says I have to pull the motor to take off the oil pan. Is that true?
in your sig, the arm, its invertedSileighty_85 wrote:some one might have pulled the oil pan before and didnt put enough RTV on it before?
Just pull the upper oil pan and re-RTV it
