Oil pan leak???
driftedtofu
Car: S14
So there seems to be a pretty substantial amount of oil on and around my oil pan. It goes all the way around the oil pan and about a cm above it all the way around. I figured it was the oil pan gasket, but Im unsure.
Any ideas/ repair help?
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
clean the living hell out of it, all the way around. nice and shiney, then run it round the block awhile. check it, you see oil, replace it. there pretty cheap
S14Nick
Car: S14 240sx
i have the same image on mine s*** must be comin
MastaYu
Car: 92 Nissan 240SX SE HB
if it is the oil pain just redo the gasket
7anshin8r
Car: 96 Nissan 240sx
I heard the oil pan was a **tch to remove and install. Something about having to remove the cross member, but I really am having a hard time believing that. I also was told I could get it off if I put the front of the car on stands, then jack the motor up to get clearance...
The confusion is the only reason I haven't changed mine yet. Got a big old ding in the front of the pan, and it leaks from the gasket.
DrJuice164
Car: 04 G35 Coupe
Front main seal????
Wc240
97 Nissan 200SX
06 Scion xB
for the pan, dropping the sway bar down outa the way should give you plenty of room. or if you want, you can just jack the motor up an inch
