Oil pan install
PMan_S13
Car: Building car -> breaking car -> fixing car -> start over
-KA24DE
Now I'm no idiot, but I swear I am having the most difficult time getting the oil pan gasket to install with no leaks...
I've probably replaced the gasket at least 4 times since I've owned this car. I always use one of the felpro gaskets with a whole bunch of the high temp red sealant. I always make sure to return the bolts in the correct order, and I let it sit for a long while before adding oil. And every freakin time it leaks.
In the whole realm of things this isn;t even that difficult of a job (besides the part where you ahve to slide the pan out from under the lifted engine, that kinda sucks) and it just seems to be evading me somehow.
Any tips? Maybe not use the gasket and jsut use a lot of the sealant?
Thanks
180fan
Car: 89 fastback
RTV only. Aim for a good bead pattern and tighten it down in the proper order and you shouldn't have any problems. Did you check the oil pan or the block for any knicks that could be causing a leak?
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
Did you throughly clean each contact surface? What made you replace the gasket in the first place? Maybe the oil pan is warped?
gumby
Car: '89 240sx sohc
make certain the mating surface of the pan isnt deformed around the bolt holes or otherwise warped. i had one that was and it ripped the gasket. fortunately i had a spare pan that wasnt damaged. otherwise i would have had to use rtv. if you use the gasket hand tighten snugly so it compresses ever so slightly. i got it on the secong try and no leaks so far.
NISTECH
the only pans i have ever seen a gasket on for nissan cars is the trans pan. DO NOT use gaskets on these cars thay are not designed with or for them. the pan has dimples in it for you to fill with sealer [RTV].
Besides IMO felpro gaskets suck.
PMan_S13
well I guess I will be doing this again without the stupid gasket..
yes, I cleaned both surfaces everytime... just never seems to work properly. Leaks every freakin time.
Thanks guys
gumby
Car: '89 240sx sohc
why do they make a gasket if it isnt supposed to have one?
i just laid a bead in the indentations and skinned the gasket of both sides.
navysnail
i dont think that nissan sells one, not sure though. i assume they just sell a gasket to make it easier on some people, but the FSM says to use liquid gasket so thats what i would use...
NISTECH
nissan does not have a gasket for the engine oil pans of any nissan ever builtafter the 70's.its the aftermarket parts houses that came up with it.
gumby
Car: '89 240sx sohc
well that sucks cause i ended up buying 2. bastards
