Oil Pan Gasket
got2b240
Car: 91' RPS13 = GT28R, 525cc, Z32 Mafs & SAFC, Blitz EXST & FMIC, Silvia VLSD
I searched and coudln't find an answer. What can I use for an oil pan gasket for my redtop? Can i use a DE oil pan gasket? Or just use silicone? What type of silicone is best then? Any help would be greatly appreciated
robbbby
There is no OEM oil pan gasket. Use that gasket maker stuff that can be found at any auto parts store. I like the black kind.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
I used nissan orange stuff. Colors are fun
nismostate
Car: all sorts of motorsports
used the high temp red from a local store. if you do it right, it's a ***** to take off once it's dry.
joe3180
Car: 89 240sx, S13 sr20det, silvia conversion
what is better to use tho...silicon or that gasket stuff? im going to replace my oil pan next week and i just want to be sure to do it right. and how long do you let it set before you drive or even put oil in?
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Use the red silicon and I would let it dry for about 24 hours.
got2b240
i actually bought a roll of gasket material (cork) and used HI temp silicone RTV. I let it sit for 2 hours before putting in any oil.
scs13
Car: 93 s13 coupe
nismostate wrote:used the high temp red from a local store. if you do it right, it's a ***** to take off once it's dry. <IMG NAME="icon" SRC="http://images.nicoclub.com/forums/image ... s/wink.gif" BORDER="0">
what is the best way to get the liquid gasket off, i am having a hell of a time trying to. somebody please give me a suggestion.
jgauspohl
Car: 97' S14 SR24VET
92' S13 S14 SR20DET
90' Golf GTI
91' S13 siltruck project
yeah definitely use the high temp red stuff...and go to walmart get a razorblade....easy as pie...and if you really want to get it all use a small wire brush. Nothing hefty just a small one little bigger than a toothbrush ...also at walmart.
scs13
Car: 93 s13 coupe
i am talking about getting the pan off while it is still on the motor. not sure if you meant cleaning old liquid gasket off while you have the pan off. but ive tried using razor blades, other cutting instruments, putty knife, screwdriver, etc etc and i cant get the damn thing off.
Nismo_Freak
Car: 89 Nissan 240SX
Get a wide spade punch and tap it in slowly. Once you get part of it in use it to pry the pan.
Carb cleaner does pretty well at denaturing the silicon gasket maker.
scs13
Car: 93 s13 coupe
thanks, i will try that. i think i might try and find the stuff they make to get it off, it takes off paint though so i didnt really want to do that.
