I have a few questions on the oil pan gasket. I know the stock setup is a liquid gasket and that's recommended in the nissan manual, but when I requested a gasket kit from autozone I got a cork gasket as well as the two pieces for the ends. I'm thinking I should just go with liquid gasket, but I wanted to check to see what others had done first.
Also, how far should I apply the liquid gasket? I'm guessing it doesn't go as far as the two rubber pieces, but I could be wrong? Thanks in advance
