oil pan gasket
gabo
Car: 1992 nissan 240sx
What gasket can be used on the sr20det?
yozsi
Car: Racing
im thinking a sentra?
gabo
i actually bought the '91 sentra se-r gasket, but it isn't.
Nathan
SR20's have oil pan gaskets? I figured they'd use liquid gasket like KA's ;)
book-ends
Car: ???? Nissan 240SX coupe S13
Wow. I checked several different websites for you but I didn't come up with anything. Huh, I always thought that gasket would be easy to come by.
I would follow Nathan's suggestion and just use liquid gasket.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Nissan liqiud gasket
gabo
thanks guys, thats what i used and its leaking. i probably didn't do it right. i'll have to crawl underneith and try again. happy new year......
Hijacker
Car: '92 240sx Convertible
'94 F-150
there are very few gaskets on nissan engines. headgasket, and valve cover are the only ones that come to mind aside from the standard metal exhaust gaskets
BuudWeizErr
Oil pan does NOT use a gasket, get some Nissan sealer and put sealer in the grooves on the edges of the oil pan and around the bolt holes and you will be fine.
ride4lame
i have to do this tommorow....i hear i have to be liberal with the sealer...any other tips then what bud said?
Hijacker
'94 F-150
that's all you have to do. there's really nothing to it, just make sure it's a complete, uninterupted bead all the way around the pan lip. it's just like when putting any part back on that requires some form of gasket sealer.
ride4lame
i haven't used gasket sealer before :( just regular paper gaskets...
ride4lame
ok, i am trying to get the oil pan off...i need to re-use it and i can't get it off...any tips ? please...i need to drive to work tommorow
ride4lame
bump, i gotta get this done tonite...thanks any ideas to make this easier?
Big Perm
are you tring to get off the factory pan?
if so just tap a paint scraper in between the pan and metal, and wiggle to loosen. then it will start to come off.
sideshow
Car: obsessed with cars.
yea they are definently liquid gaskets because i rebuilt my ka, and there are actually only 4 gaskets on the longblock including the liquid gasket on the oil pan, but then there are throttle body gaskets, intake runner gaskets, exhaust and intake manifold gaskets oil pump/ timing cover gasket. not too many
spitz7985
Car: HICAS S13
if i were you i would def. go to a dealer and buy some nissan liquid gasket ( the red stuff). i sealed my oil pan and front cover with cheap **** from autozone and it's leaking like a ***** now.
DAEDALUS
Car: 1990 Infiniti Q45
It's imperative you clean all mating surfaces really well. If there's any grease or oil anywhere, the RTV won't take a good bond and the seam will leak much sooner. Use simple green or something for the bulk of it, then go over everything with brake cleaner. Use a white rag so you know how clean it is.
Trppen37
Car: CA18DET
Nathan wrote:SR20's have oil pan gaskets? I figured they'd use liquid gasket like KA's ;)
then whats this gasket??? http://www.nismoparts.com/catalog/?section=324
Pan Gasket??
IveBeenBad
Car: 1990 Nissan 240SX Fastback STOCK BIOTCH
SOHC only... never seen a SOHC SR
