WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Sat Nov 25, 2006 8:27 am
I"m from the school of "to much is just enough" Of course this has sent me to the junkyard looking for new motors on more then one occasion, but thats because boost is worse then heroin.
BAck on topic, I've used Permatex and RTV, both with great results. On helo's we have a general rule and are actually trained when it comes to applying certain types of sealant for anti corrosion purposes etc. The key is called the squish factor. You want to use just enough sealant to have a small bit squish from the sides. This insures even coverage. I've used this method I'd have to say 45 times by now on motors alone, not always the pan, but it works there as well.
I just spilled hot coffee all ****ing over myself just now....****
Back on topic, Can you unbolt the oil pickup, sit it in the pan, position the pan then reinstall the pickup, bolt up the pan...done.
Try that, I had to do it that way on my RB20 everytime, there just wasn't enough room.
WD
