I H8 UR DSM »
https://forums.nicoclub.com/i-h8-ur-dsm-u121.html
Tue Jan 14, 2003 8:22 am
ps, i have a greddy oil pan, and did not use an actual gasket....and i did check with a couple of other people before i gave you that information : ) so its not just me....I used a razor blade, and carefully cleaned the old gasket off, without digging the razor blade into the metal, and making any marks or anything, just carefully clean the part on the motor, the oil pan has a grove so put the sealant in there carefully, get it fully around, then put it on gently, and tourqe it up, it will ooze out the outside of the oil pan a little, let it, dont try to use the razor and clean it, just let it ooze : )
(my description isnt the best, lol, but im sure you get it)
