_b.jaye_ wrote:if you dont have a robot like the OEMs do to uniformly & precisely apply the RTV to have an RTV only gasket, id recommend a formed aftermarket gasket. provided you really do need to replace the factory RTV joint...
not saying it cant be done, just sayin im pretty sure they make'em & i doubt its more than 10-15 bucks
less chance for leaks, not much more expensive, waaay easier
You're speaking hypothetically of course because in reality any r-tard could make a gasket with RTV sealant. I've removed and installed about 15 350Z oil pans and used RTV per the manufacturers service manual on every one of them and never had any issue. There is no "less chance of a leak" with a hypothetical formed gasket which I have never heard of because it doesn't take a master mechanic to lay a bead of RTV that won't leak.
Work on your car much?
