locoluna825 »
https://forums.nicoclub.com/locoluna825-u93365.html
Sat Mar 06, 2010 6:43 pm
You probably should have gotten rid of that oil after you fixed whatever was cuasing fuel to go into the oil. I dont believe a leaky pan gasket or front main seal will cuase white smoke. Ive had both those problems and never had any white smoke. the white smoke coming from the exhuast right?
Theres information on how to remove the pan if you use the search. I just did mine folowing someones tutorial.
Only thing I didnt do from the tutorial. Was actually hoisting the engine up. becuase i dont have anythign to hoist from. Instead, I used a jack, once the motor mounts were unbolted, to lift the bellhouseing of the transmision up to make enough room to get the pan out.
Took me a good 5 hours becuase ive never done one before. Kept removing things i didnt have to and putting back on. But if you got 2 or more ppl that now how to drop a pan ittle be pretty short.
