Drake57 »
https://forums.nicoclub.com/drake57-u87237.html
Mon Sep 08, 2008 2:52 am
I searched but so far have not seen any procedure for dropping the oil pan. I think it involves supporting the engine from above, dropping the sway bar/cross member/rack&pinion/lower suspension, then unbolting and dropping the pan.
I've looked, and seen what looks like a lifting loop on the passenger bank, toward the rear of the engine, and no loop on the driver side. Can anyone say how to attach to and suspend the engine?
I have an engine lift, but I'd prefer to make a stand that will sit on the car body between the upper mcpherson strut mounts and fender bolts - the engine lift will get in the way underneath the engine.
Lastly, are pan gaskets available? If so I'd like to use a gasket rather than rtv.
