estil0 »
https://forums.nicoclub.com/estil0-u69229.html
Tue Apr 07, 2009 11:03 am
I pulled the front of the motor off come to find out that the guides were already replaced.. Pondered for a bit, then I came to the conclusion that the f***ers at the dealership probably did not want to go through the trouble of dropping the pan. Therefore, plastic from the guides must have jammed the oil pump. Sound like I'm on the right track ? If so, then can I cut a corner by slightly raising the motor with a jack and have clearance to drop the pan? Or do I need a hoist ?
