i will not be at VIR this weekend, finishing my cage and stack cluster install.bimrtech wrote:Are the KA pans steel?
I made my own for the VG racer. It is low budget and ghetto, but I am not spending money on some high dollar pan. I made the kickouts out of steel from lowes. Just made square boxes. I used small door hinges for the trap doors. Welded the holes shut and welded the hinges to the sides of the stock pan where the kickouts were added. I used a spot weld on the hinge itself so it would only open up towards the oil pickup.Worked great when filled with water and tilted side to side. Thats all the testing I did.The car weighs 1700pounds and has 10 inch slicks so it pulls some g's in the corners.
SR20goofus see you this weekend at VIR?I am in the ugly mini stock car looking thing in the stinger group.
Modified by bimrtech at 11:51 AM 2/18/2009
Yes I agree, nothing will help you pick up more speed than racing.Getting some help from a racer will be the next best thing.sr20goofus wrote:not racing this year, tho i am getting some help from a few racers at the march event to help me pick up more speed. Still instructing at least this year, funds dont allow racing when instructing is so easy and cheap.
ill be by the se-r guys anyways to get someone to rid-along with me, so i will deff see you if not friday before saturday at some point. My car is all back together, just doing some final parts install and th cage is baller.bimrtech wrote:Just wanted to give an update on the ghetto oil pan baffles made on the VG racer. GREAT!!!!The water testing proved well.Track test showed no drop in oil pressure as previously experienced without the ghetto baffles. You really can make a pan work for 20 bucks at lowes.
sr20g... hey signed up for March at VIR come by Sat. White Dodge Durango with ugly black stock car want to be #59I am normally around the SE-R guys.
