Don't know about that. But do as I said and remove the filter once or twice to achieve the proper oil level, it shouldn't take more than 15 minutes to do.I35JUGA wrote:It was cold, i read few online site that will cause seal to leak ( like rear main seal ), is that true ? I just dont want the car to be money pit in the future
I recently got my transmission oil changed, and its been over filled, how do i drain it? now i'm getting worried... maybe thats why its shifting hard from 1st to 2nd.patqx4 wrote:Definitely drain some out. Overfilling is as bad as underfilling. When I got my truck the transmission was overfilled a LOT and I hit the roof when I saw it. First thing I did to her was drain that to the correct MAX level. Lazy mechanics who wont bother to get the level right really piss me off.
-Pat
Disconnect the cooler return line (passenger side), secure the hose in a bucket, have a friend turn on the engine, drain some fluid, yell for friend to shut off engine, adjust level as required.cpta2020 wrote:I recently got my transmission oil changed, and its been over filled, how do i drain it? now i'm getting worried... maybe thats why its shifting hard from 1st to 2nd.patqx4 wrote:Definitely drain some out. Overfilling is as bad as underfilling. When I got my truck the transmission was overfilled a LOT and I hit the roof when I saw it. First thing I did to her was drain that to the correct MAX level. Lazy mechanics who wont bother to get the level right really piss me off.
-Pat
Towncivilian wrote:Disconnect the cooler return line (passenger side), secure the hose in a bucket, have a friend turn on the engine, drain some fluid, yell for friend to shut off engine, adjust level as required.cpta2020 wrote: I recently got my transmission oil changed, and its been over filled, how do i drain it? now i'm getting worried... maybe thats why its shifting hard from 1st to 2nd.
No. you check the oil with the engine NOT running.patqx4 wrote:Just make sure youre checking the level with the engine warmed and running.
Sorry Chuck, you are absolutely right engine oil is checked with engine off. I was replying in regards to transmission fluid. Sorry for the confusion. That said, I would recommend the same proceedure to correct the engine oil level. (release oil via drain plug, check level.)Chuck Tribolet wrote:No. you check the oil with the engine NOT running.patqx4 wrote:Just make sure youre checking the level with the engine warmed and running.
From the '01 owner's manual:
CHECKING ENGINE OIL LEVEL
1. Park the vehicle on a level surface and
apply the parking brake.
2. Run the engine until it reaches operating
temperature.
3. Turn off the engine. Wait more than 10
minutes for the oil to drain back into the
oil pan.
4. Remove the dipstick and wipe it clean.
Reinsert it all the way.
5. Remove the dipstick again and check the
oil level. It should be between the H and L
marks.If the oil level is below the L mark,
remove the oil filler cap and pour recommended
oil through the opening. Do not
overfill.
6. Recheck oil level with dipstick.
It is normal to add some oil between oil
changes or during the break-in period, depending
on the severity of operating conditions.
Ouch, being a quart over when cold, is like being 1.5 or maybe even 2 quarts over when hot. (Oil expands when hot). The marks on our dipstick are meant to be read when hot (engine at operating temp).I35JUGA wrote:It was cold.
