look like oil is passing your turbo's seal...curbsurfer253 wrote:I've been running Mobil 1 10-30 full syn and I've noticed a little oil being spit out of my blow-off valve into the engine bay. There is also a little accumulation in the ic pipes. is this normal or should i try switching to a thicker oil like Mobil 1 15-40? I might try a Motul 300v 10w-40 or 15w-50. Check out the link- http://www.motul.com/uk/conseils/index.html
