Oil out of BOV!?
Ilvemynissan
Car: 240sx s13
Ok I have a Redtop SR and there is oil coming from my BOV. I have never heard of this before and I couldn't find anything on it. Do you think it could be a bad o-ring on the turbo or somthing. All help is appreciated thanks.
Emperor_Tha
most likely its the turbo seal. Maybe u might get lucky and its the turbo sucking the oil from the pcv system. This happen to me but the oil was leaking from the intake pipe before the turbo. Catch can fix that problem.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Sounds like a blown seal in the turbo. sorry man.
Ilvemynissan
Car: 240sx s13
Well thanks for helping, i'm gonna try to fix it this weekend. I found this thread, anyone have any suggestions, tips/hints before I start this? And thanks again for the help!
zer...30329
S13FASTBACKSR
Car: '92 Fastback SR powered
Its just a little oil residue right? like buildup/ sludge kind of thing? your bov is not dripping oil or blowing loads of oil out correct? its probably just blow by mine does it and a lot of sr's do im surprised nobody else chimed in saying that.
yfs200mxr21
Car: 95' Zenki
my bro's srt4 does this too. It's normal to happen says my bro
Ilvemynissan
Car: 240sx s13
I'll take a picture tomorrow to show you, but it seems like a lot to me.
480sx
Car: 1996 Pearl White 240sx
First off, having oil in your intercooler piping is not normal, and not good. Oil will trap heat in, and generally make a mess of your IC system. Your intercooler will begin to work less efficiently if oils coating the rails.
One of two things has happened. Either your oil ring on the compressor side of the turbo has failed, or your PCV system is sucking up oil into the intake. If its just your PCV system, add a catch can. If its your turbo, you need to either get a rebuild done or buy a new turbo. Might be time to upgrade.
homeslicej2
^this is true, but some minimal blow-by is expected in a turbo'd engine. In larger amounts, it is usually an issue of bad turbo seal or the PVC system. As for oil on the IC and piping, this will happen. That is why you have to have the IC cleaned periodically. Kind of like dipping an old, used radiator that still holds pressure, but has years of gunk built up in it.
S14toRPS13
Had the same problem too. Due to blowby and no oil catch can. Blowby went straight into the intake pipe, into the turbo, and intercooler. Catch can fixed the problem.
MeanGreenS13
Car: 2011 Chevrolet Silverado 2500HD
in my experience your always going to have a slight residue in your bov. Any more tho, i would start to worry, I remember when i puked a turbo, there was a big oil splatter on my hood lol
James@CI
Car: 89 Nissan 240sx with SR20DET
I had oil comming out of my blowoff till I got a catch can and mine was just pulling oil into the intake through the valve cover
MeanGreenS13
then again you do have an SR... which has the most screwed up crank case vent system ive ever seen...
driftset
Car: notch top powered s14
so i think were talking about 2 diff issues here,blo-by and turbo seals i think i have a combo of both because after last summer my ic was really gunked but but i didnt notice any smoke or lack of boost , but i did clean all the pipes and had the ic boiled bolted back up and the car feels very strong, still gonna try a catch can though good luck to all...
nzmoman
Car: 240sx 2 of em' and always lookin for more
I just got an s14 motor with an s15 turbo. The inlet on the compressor side has this residue, but the intercooler piping and the cold air blower side are clean, does this sound like what you are talking about. Because the residue is before the turbo and not after I think its buildup from a not so clean induction filter. The turbo seems fine, no leaks on the exhaust side, very minimal shaft play. Spins freely by hand, it just has some junk on it.
Ilvemynissan
Car: 240sx s13
Here's a picture (sorry for the cell phone pic), You can't really see how much is there but there is oil dripping from it and it sprays on my intake piping.
Edit* And is this a recirculated BOV? i'm not sure
[IMG] [/IMG]
inkslingers13
Car: 1985 Corolla Gt-S
recirculated BOV??? dude that is atmospheric. recirculated is when you dump your bov back into the intake on your turbo lol.
Ilvemynissan
Car: 240sx s13
I'm glad I could make you laugh with ma nub questiom
inkslingers13
if i do remember right when i posted a NOOB question you posted a ton of bull$hit putting me down. and thats about as noob as it gets
Sleepy240
Car: 1990 Hatch
looks like a blitz DD bov, which as some others said is atmospheric. If its "spraying" from the BOV this is definetly not a good sign. It might be time for a turbo upgrade =)
Ilvemynissan
Car: 240sx s13
You sir are dumb, I posted a bunch of BS?, No I told you to search and you started freaking out cussing and all that, I posted a 'search' link, then, after that, I posted like 4 things that should of helped you and you didn't even bother to open them, You just thought I was putting more 'search' links there, So you started freaking out even more and cursing more, then it got locked, then I searched for like an hour on how to get ahold of the guy who locked it, (i found him on another website) and told him the links I posted were helpful, So he unlocked it an you got the help you needed.
nzmoman
soooo,
what is the condition of your turbo? Im interested in this, because the s15 turbo on my sr is supposed to have fairly low miles @ about 10k. and 10 psi.
inkslingers13
nope! you didnt help me one bit. but have fun with your recirculating blow off valve that squirts oil
Ilvemynissan
Car: 240sx s13
The motor has about 216,000 Kilometers, stock turbo and everything
Sleepy240
Car: 1990 Hatch
Your best bet at this point is disassemble from the turbo out. Remove the turbo, IC Piping and Intake piping. Check all those for build up, clean it out. While everythings out check out the turbo. Like others said its probably a blown seal but with everything out you'll have a much better idea and there wont be any more guessing. Its a fairly straight forward removal also.
Ilvemynissan
Car: 240sx s13
Yah I plan on doing it soon, it might be a while till I can post back up i'm gonna be gone for a while
