emerald-j »
https://forums.nicoclub.com/emerald-j-u73082.html
Tue Sep 11, 2007 9:59 am
PCV valve stuck open. Inspect your pcv and if it still stays open after checking it out, replace it. Just in case, pcv stands for positive crankcase ventilation. The pcv is really suppose to pass blow-by gasses (unburned mixture that got past the piston rings and got to the crankcase) back through your intake to finish burning what was left over. But if your pcv stays stuck open, over a period of time the oil that is splashed around in your crankcase will sooner or later make its way to your intake tract. If you want to find your pcv, follow the hose that is atached on the accordian pipe behind your afm. the hose goes just right under the intake plenum but then comes up right behind the plenum on the driver side of the engine block. that will be your pcv.
