oil on spark plugs
EM.TT
Car: 91 300ZX TT
08 Silverado All-Star
07 R6 (track)
Anybody had this or know what could cause it?
SilverTwin(OH)
Car: '91 300ZX Twin Turbo
Leaking valve covers is the common culprit.
EM.TT
Car: 91 300ZX TT
07 R6 (track)
Even if it is on the threads and the firing end of it?
SilverTwin(OH)
EM.TT wrote:Even if it is on the threads and the firing end of it?
In that case, no. Oil on the plug can be blowby or a burnt ringland, I would suggest a compression and leak down test.
Are you certain it is oil and not fuel?
es.biggs
Car: 1990 300ZX 5sp NA
He's right - fouled spark plugs can look dark, dirty, and wet (oily looking) from fuel.
+1 on the compression test and leakdown test
marty1mc
Car: 1990 Nissan 300ZX TT - Z owner since 2003
If there is residue on the plug, you can tell if it's fuel or oil. Fuel residue will be crusty and break apart on your fingers. Oil will smear. Also, if the oil on the plugs is very fluid, it may have leaked down the plug when you pulled it if the plug cavity was full of oil.
EM.TT
Car: 91 300ZX TT
07 R6 (track)
I'm pretty sure it's not fouled, i put the plugs in when i bought the car and it hasnt ran since (it has only been cranked over) and all the other plugs still look as if they were just removed from the packaging. I guess i'll have to see where a compression test puts me. Thanks guys
timsz
Car: 1991 nissan 300zx na 5 speed lowering springs and powertech exhaust.
My car has the same problem only it smells and looks like fuel but with a little oil mixed in. I just changed them today so its fresh on my mind, the coil packs boots have oil on them too and 2 of them (both on drivers side) were ripped? How does that happen? I just recently bought the car so I do not know when the last time it was serviced. Oh and it was missing a little bit thats why i changed them. Any help would be great. Thanks, Tim
