Spooled_GTIRSENTRA »
https://forums.nicoclub.com/spooled-gtirsentra-u47677.html
Tue Apr 17, 2007 2:34 pm
I have the gtir (sr20det) in a 93 sentra. and im just workin out one problem at a time.. any ways. It ran for a day or two (very poorly), now wont start. i know it needs a tune and im just running just the downpipe. it started just fine for like 2 weeks, i took it for a quick ride and the oil pressure peaked just over 100psi. i know, thats not good. at idle it should be 14psi and at 3200rpm 42-60psi. anyways, it wont start now. i pulled off the spark plugs and oil is on all over them. i checked compression and all 4 were within a few of 150psi (cold engine). so thats all good. but what could be causing oil on plugs. im thinkin mabe the guides are bad, and ive herd sr20 guides are known to be junk. anyone have any thoughts?
Thanks, Tony
