oil on spark plug #2
popone913
Car: 96 Maxima GLE
I was regapping the spark plugs and cleaning them up and I pulled my spark plug out of cylinder #2 and it had oil all over it. Is it the head gasket or the piston ring? Or is it something else? VQ30DE 96
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Have you changed your oil since you found this? A bad headgasket can lead to coolant in the oil. Alternately, blowby caused by bad or misaligned piston rings can lead to sludge.
popone913
Car: 96 Maxima GLE
I'll be changing the oil tomorrow because it's due... is changing the oil good or bad?
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Good. Changing it is always good, but in this particular instance, you can look at the old oil after you've drained it to see if it's got any coolant or sludge in it as mentioned above.
