guyaverage »
https://forums.nicoclub.com/guyaverage-u13673.html
Sun Jun 25, 2006 8:59 am
Your valve oil seals are shot, pretty common for a higher mileage KA. They are cheap to replace yourself, I got mine off eBay for I think $16. If you have the proper valve spring tool, you can get the job done in about 2-4 hours. If you dont have the right tool, it will take MUCH longer. If you pay someone it probably wont be cheap. Its not a good job for a first-timer or if you havent worked on engines much.
I was burning about a quart of Mobil 1 every 700-1000 miles or so. I put my new seals on about 5000 miles ago, and it has not burned a single drop since, if I am to believe the dipstick.
