oil looks like chocolat milk
momo4l
Car: 1989 nissan 240sx
my car overheated so i checked my oil and it looked like chocolat milk so i replaced mt head ,head gasket, and my intack just for good measure but it still doing it what can it be pleas someone healp me do i have a cracked block or what?
Logan76
Car: Junk
ummm, maybe your new headgasket wasnt installed correctly and its still leaking?
onepuff
try doing a compression test
180fan
Car: 89 fastback
did you check the head and block for warpage when you did the head gasket job?
Brunos14
Car: 1996 Nissan 240sx (S-14),1966 Datsun Roadster 1600 (SPL311)
Yea your block could have been warped too.
carbonkid
Did you flush your radiator?
StuntingShaggy
Car: 1991 240sx
Ummm sorry to tell you this but I believe what may have caused your head to warp was when you overheated it after you replaced the headgasket and all that other stuff. Thats when most blocks warp and let coolant get in, when they overheat. The blocks only go up to a certain temperature before starting to melt and change shape.
dkdeleon68
Car: 1991 240
check your upper and lower timing chains for looseness, what could have happened is that your chain is loose from being stretched and old and it wore a hole in the block. I've seen this happen many times.
NCturbo75
Car: 2006 INFINITI M35...
"chocolate milk" looking oil means a mixture of radiator fluid and motor oil. The last time I saw that meant a CRACKED cylinder wall. Of course, you may have a bad headgasket, too.
