DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Sun Nov 13, 2005 11:10 am
i pulled a KA last thrusday and two days ago useing a scaffolding and a come-a-long. you dont need a hoist, or worst comes to worst rent one for like 10 dollars a day. if you cant find a rental place you havent even looked yet.
the best you can do is raise the car, drop the transmission then pull it out. then remove the clutch and all that jazz. then you just unbolt that plate. that plate is also gonna need a gasket, so tht could be your problem too
this is gonna become way too much aof a problem without pulling a motor, unless you like to work on your back, you slut....
