oil lines question, please help ASAP!!
Hit_N_Run-player
Ok, so im going to be running a t25 from an SR20 on my ka24de-t setup. I have a .60 1/8" oil restrictor, is this right for a t25? Should i use a -3 an line with or without the restrictor, and is that the right size? What size drain should i use for this turbo? Please help ASAP, i need to get lines soon and i get payed tomorrow.. Thanks, and any info would be helpful.
Nissan_240sx
Car: 1992 240sx
You should be fine without a restrictor for the -3 line, -4 you should use a restrictor. for the drain I think it was 10
