oil line
mr. silvia
Car: anything doing with cars
i am about to upgrade to a top mount sc50 turbo.. and i need to get an oil feed line and return line... where can i get a good setup?? thank you
teddy
Car: Saab Turbo and MR2
Taka makes an oil feed line for an sr block and line to a t3 turbo. I'm assuming that the sc50 uses the same inlet thread as a t3..which is a 1/8" NPT.
You could also assemble your own line. You'd need a 12x1.25 to -4 an metric adapter, a -4 AN line with 2 female ends in your choice of length, and a 1/8" NPT fitting..both male ends. You can get all those parts from ANplumbing.com. As far as the return goes, I just used a 5/8" silicone oil line and an aluminum drain flange, from the turbo to the oil pan.
