oil line help
skatanic28
Car: 96 240sx
im tryin to get a kit for my ka24de and top-mounted t3/t04e. i was gonna go with cheapturbolines.com but they seem to be having trouble lately. if you guys could help me out with this i would appreciate it, i suck at fittings.
http://www.jgstools.com/turbo/index2.html
TA004 48" line w/ std. 1/8" pipe adapter TA005 18" Length TK028 T3 & T04 flg. $29.99TA046 1/2" NPT Steel bung $1.99 TK027 T3 & T04 series Inlet- 1/8" NPT
does this look like everything i would need?the bspt adapter is used between the block and adapter right?, so then how does the stock oil switch fit onto the adapter?what is used between the turbo inlet and the feed line?
thanks
driftjunke
If you look for a hydraulics place around you somewhere, they most of the time can make the lines you need for about 20 bucks for a oil feed, thats what we do here at the shop.
J.D.http://www.e-emotorsports.com
