Oil line help
danielmcn
I need two fittings to hook up my oil feed line. One for the block and one for the turbo. I am using a HX35 and its going on a rb20. I am trying to hookup the -4an male end to the block (stock oil bango bolt hole) and the nut looking end to the turbo.
I have a line like this. http://www.ebay.com/itm/36-TURBO-OIL-FE ... 33558d92aa
Looks to be the same size.
Anyone know what size fittings I need and where to get them?
danielmcn
WOW Nobody has any imput.....
Nesquick
Car: Rb26 Kouki Silvia
took me all of 30 seconds to google "rb20 oil feed"
first size came up was M12x1.25..... dont know if thats right because i have an rb26 and dont know of its the same or not.
thats for the feed from the block... i can guarantee you can come up with the other sizes because i am sure it has been covered many times.
search around a bit...
danielmcn
I guess I should have said I know what size bolts came out and what the pitch is. I just cant find a 12x1.25 to female 4an anywhere. I found the one for the turbo side.
chad b.
Car: chocolate chip kouki
danielmcn
See I have a line, but its got a female and a male end. I guess I just need to buy a new line.
I found a ton of those fittings, but not one single fitting with a female end. Thanx for the links I guess I will have to change it up abit.
