480sx »
https://forums.nicoclub.com/480sx-u50548.html
Thu May 08, 2008 11:37 am
I used the JGS oil return kit. You really cant beat the value and quality of it. IIRC its about 30 bucks. You get the heavy duty piece of drain hose, the oil drain flange for the turbo, a gasket for that flange, the steel bung for your oil pan, along with two high quality hose clamps that wont pinch the hose.
I would recommend putting an angle on the steel bung so when you weld it into the pan its pointing up instead of strait out, or down. With the way the oil pans shaped, welding the bung strait in will make it so the bung has a downward angle on it.
