OutToWinPAHC »
https://forums.nicoclub.com/outtowinpahc-u66900.html
Mon Nov 23, 2009 8:51 am
-Check the oil level again on the dip stick, make sure its there.
-Check coolant make sure there is no oil floating in it.
-Check the connection and terminals on the oil pressure sensor located next to the oil filter. With battery disconnected clean the terminals, and see if it helps. Start the car, if the light is still on after 2-5 second shut it of and move on.
If you have oil, you have one of 2 problems. The oil pressure switch is bad, or you are not making oil pressure and need an oil pump.
I would then replace oil switch. Its a simple NC 2 wire switch that opens when pressure is near 10psi. Since the light is on, the circuit is working. So replace the switch, verify there is oil in the car again. Start the car, if the light is still on after 2-5 second shut it off because you need an oil pump.
