DEATSCHWERKS wrote:The hardwire kit is a kit we put together to bypass the OEM wiring and power your fuel pump directly from the battery. Full instructions are included which better explain it. But basically, we use your OEM circuitry to power a relay which then switches on the power directly from your battery to your pump. Once installed the system is completely transparent and seamless. The pump primes, turns on and turns off, just as it would if it were wired OEM. So you don';t have to worry about any toggle switches or anything. Just turn the key and drive!
