Syntax360 »
https://forums.nicoclub.com/syntax360-u3690.html
Tue Mar 18, 2003 7:23 pm
Sorry this is so long, but i think it's necessary to understand the problem. I've had troubles with my valve cover recently. It was painted, put back on, and stayed fine until the gasket finally gave (I know, I know: i shoulda changed it right away) and after I took it off, bolted it back on, etc and used silicone as a makeshift gasket, it ran fine but i took it right to my shop. They installed 2 new gaskets, heliocoiled 10 of 11 bolts (they were shot) and generally put the whole thing together. It drove fine for a day. One day later the oil light came on. I took it back, they replaced the oil sending unit switch or something (they said it was leaking....whatever) and the light remains on. They then come to me, nothing else done, and proclaim I need a new engine. They say there's no way to fix it, blah blah and I'm generally screwed. Does this sound right? They replaced a switch and right away decide my engine is on its last legs. Couldn't some silicon or metal shards from the heliocoil have slipped in and clogged the filter or something very simple like that? Perhaps I'm just that ignorant about these things,, but it seems rash to say the engine is toast w/ no other info than the oil sending unit isn't the problem. Thanks!!!!
