Q45tech wrote:Most non Nissan specialty shops don't have a Consult I or II so they cannot even accurately measure the idle rpm since the inside tach is very in accurate below 1,000 rpm.
What's scarey is the sensor make leak but rarely fails in its duty to show whether you you have at least 3 psi which is 11 below minimum spec.
Raising idle rpm until the light just goes out is worthless what you must do is raise the rpm until you achieve 14 psi.
I think i kinda understand what you are saying.. I think thats what the mech was telling me and i looked at him because it sounded as jibberish and reading it typed on here. They have the consolt there... He also said something about he needed to check the air control or something like that as well.. Ive looked into getting another engine.. Not that expensive, it is the labor thats expensive. To get the swap and fluids and all dat crap, i was told 2 grand. Only thing i liked was that he said he would swap all my part. But while engine is out, i wanna get all 8 injectors replaced.. So thats another umm... like 1500$ if im not mistaken right?.. Sounds like almost 5 grand there... I think thats like the only thing i havent replaced under the hood.
Im also gonna try to run some BG 44k.. cause i street mech said maybe the filter inside oil pan is clogged.. I told the mech at teh shop... he said that was jibbersih, and that person didnt know what they were talking about. ** the price i pay for a Q**
