osofasts13 »
https://forums.nicoclub.com/osofasts13-u11703.html
Thu Feb 19, 2004 4:54 am
just recently my car started to knock, well it will knock when you start it up and then when it gets warmed up it will go away. sometimes on cold starts the car will start up and the oil light will be on and the knocking will be horrendous. what is going on with my car. i could only pin point it to the lifters, oil pump, or timing chain. the only reason i think it is not my oil pump is because the oil problem is a on and off thing, depending on the weather, cold or hot. could the lifters be causing this?? if so how hard is it to replace it and how much does it usually cost for new lifters? is it worth it, my motor has 178,000 miles on it??? this is on a 91 ka24de.
