Someone shed some light on this for me? I'm starting to get fed up with my 240
*Sorry for the long post*Thanks in advance*
Intermixing?OutToWinPAHC wrote:Stop driving that thing ASAP. Try a new pan gasket, check for leaks, check for intermixing. You may be lucky and that's all it needs, but from now on, if you have an oil light pull over and shut it off asap.
Yeah pressure gauge is going in this week...OutToWinPAHC wrote:Its an oil pressure switch, pressure drops when the pump is bad, pick up is clogged, of the pick up isn't picking up oil because its low. If its leaking fix it, and you should get a pressure gauge on it.
Thanks for dumbing it down for me!!OutToWinPAHC wrote:After you replace the gasket and fix the leak, fill, and change the filter try running it. But use an oil pressure gauge to see what the oil press is. Sometimes the oil pressure switches for the cluster light do go bad, but its good to know. This way you can see if if is the switch, or an actual pressure loss (bad oil pump / clogged pick up)
Just because you have low pressure doesn't mean you are low on the actual amount of oil you have. Thats why it might be your pump because if i remember correctly our pumps move oil at high pressure not high volume but of course if you are to low on oil no matter how hard your pump is kicken you wont get enough pressure. So find out why your losing oil, and why your oil pressure is low, it might be the same reason or it might be 2 different problems.NICONick wrote:Thanks for dumbing it down for me!!OutToWinPAHC wrote:After you replace the gasket and fix the leak, fill, and change the filter try running it. But use an oil pressure gauge to see what the oil press is. Sometimes the oil pressure switches for the cluster light do go bad, but its good to know. This way you can see if if is the switch, or an actual pressure loss (bad oil pump / clogged pick up)
