na3j nitsuj wrote:well i only used 4 quarts of oil...so do i jus add some more?how would i know if i already placed too much...cus the oil stick already states that the oil level is high...should i still add more?
Well, like The One said, if you're checking it on the cold engine, the oil may have made it's way back in to the pan depending on how long it's been sitting. Not sure how you plumbed your filter or cooler, but if you added extra volume to the oiling system you may need to add more.
The next thing I'd do is check the oil pressure sender. Bust out your multimeter and FSM and see if the sensor is working.
You may want to consider getting an actual oil pressure gauge and ditching the warning light. Autometer gauges are cheap and good quality.
