So I'm assuming oil consumption in these cars are high then. Because I have no leaks what so evermdmellott wrote: ↑Wed Sep 08, 2021 7:13 pmWhile the engine is running, oil is going everywhere inside the block so of course the dipstick is covered with oil. This is why you should never get the oil level while the engine is running. You are probably at least 2qts low is the light is coming on. Fill it up!
It depends on how well maintained the oil changes are made. I change mine every 3K miles, as per Nissan's scheduled maintenance, and by that time my '02 will have burned about half a quart.peteralvarez91 wrote: ↑Wed Sep 08, 2021 7:16 pmSo I'm assuming oil consumption in these cars are high then. Because I have no leaks what so ever
Alright will do, I remember putting in 5 qt what the manual said to do but I guess next time do 5 and a bit more... Do you guys recommend synthetic and also going up 10w-30? Or just stay at 5w-30?
macgiver wrote: ↑Wed Sep 08, 2021 6:58 pm2nd that , Rogue = the HAMMER here , Rogue one tough cookie , nico's 'enforcer' if you will , keeps it right ,keeps it slight , not real mean - just real clean .
What would we do without Rogue ? " That cat Rogue 's baaad mu-fa , waych yo mouth- I'm talk'n bout Rogue ??"
Hmm alright for sure.. Btw I pick up this pathfinder months ago and I'm not sure what the previous owner might have done with it as far as maintenance but I basically brought this thing back to life and up and running, I'm new to this platform btw.. I'm more of a bmw person but I love the truckmacgiver wrote: ↑Wed Sep 08, 2021 7:27 pmWhy not 5-40 , cause ya got the flicker , so stay 5. Then the CONSUMPTION ?? So goto the 40 " at temperature" - thus 5-40 , also ester oil like Motul 300V 5-40 has high surface tension , and the group V (five) stock many say superior , just a suggestion - only a suggestion .
Ah yeah you f*** up with that engine
Yeah that's basically the one that I used this past oil service that I did on it. So then if I'm missing oil and a low reading of my dipstick says I'm missing atleast 2qt is that normal on these pathfinders? I've only ran about 2k with this oilmdmellott wrote: ↑Wed Sep 08, 2021 7:43 pmI use 5w-30 full synthetic Castrol Edge High Mileage because I'll burn less than conventional or synthetic blends between oil changes and the additive in this Castrol brand keeps my old seals well conditioned so they do not leak. But here's the rub. You said your engine is not leaking any oil and that's great. However, synthetic oil has a much better, higher flow rate that conventional oil and it is sadly to often the case that when one switches to synthetic in an older engine that has seals which are just hanging on and doing their job, synthetic's high flow rate characteristic has a way of finding its way past the seals and even the valve cover gaskets. It's not all bad news if you do find that synthetic oil starts leaks you never had before if you use the High Mileage brand with the seal conditioner additives because those additives may actually rejuvenate, to some extent, those old seals and eventually stop the leaks from continuing if you're lucky.
You'll be alright its just the money to fix all that is alot and to keep up with the maintenance that's key and lot of ppl are not up for it. I suggest you find a good bmw tech tho to help. I usually to all my work on all 3 of my cars but I always got my back up tech just in case. Well I'm learning with the pathfinder but up to today much easier than bmwmacgiver wrote: ↑Wed Sep 08, 2021 7:50 pmAbsolutely Peter , I heard horror stories AFTER I bought that 650 , the smoking- valve seals , PCV's ,trans seal R&R , but I knew enough to start cold a prospective , look for smoke ,look for smoke ,look for smoke.
I was lucky too , SH!$#TT it only had 61kmiSeveral Bimmer mech's I know envy the buy, say it's a F'n Gem !!!!!!!!!!!!
Not normal in an engine like ours that has had consistent oil changes at 3K to 4Kmax and not allowed to run low, like it is now. Once the bearings start burning oil, there's not much you can do to stop it other than using oil additives like Lucas Oil High Mileage Oil Stabilizer to slow down the oil consumption. https://lucasoil.com/products/engine-oi ... stabilizerpeteralvarez91 wrote: ↑Wed Sep 08, 2021 7:50 pm... my dipstick says I'm missing at least 2qt is that normal on these pathfinders? I've only ran about 2k with this oil
I've never used oil additives in my cars, my bmw n52 engine has 160k and barely burns any oil. So every oil change use the whole qt plus the 5 qt of oil?mdmellott wrote: ↑Wed Sep 08, 2021 8:02 pmNot normal in an engine like ours that has had consistent oil changes at 3K to 4Kmax and not allowed to run low, like it is now. Once the bearings start burning oil, there's not much you can do to stop it other than using oil additives like Lucas Oil High Mileage Oil Stabilizer to slow down the oil consumption. https://lucasoil.com/products/engine-oi ... stabilizerpeteralvarez91 wrote: ↑Wed Sep 08, 2021 7:50 pm... my dipstick says I'm missing at least 2qt is that normal on these pathfinders? I've only ran about 2k with this oil
