steve_c »
https://forums.nicoclub.com/steve-c-u163301.html
Mon Nov 23, 2015 6:34 am
Well, I cannot explain why your readings were so erratic, except that the oil did not have sufficient time to "level out" (settle in the pan) at the times you performed your oil level checks.
Was the car sitting for a decent amount of time (engine off)?
Level surface?
Did you let it sit after adding oil and again before re-checking level?
Was your dipstick fully seated?
Do you pull the dipstick at least 2x per check, wiping down stick between checks?
I can never get a good reading after adding oil because the oil is smeared all over the stick. Same after I shut down the engine. It takes several dipstick wipes to clear the oil from the stick under those conditions!
If I want a super accurate stick reading, I take it after the car sits overnight before start up. That is the best time to check.
If I need a reading after driving, I let it sit at least 30 full minutes to an hour for a good reading.
If I need a check after shutdown, (no or little oil settling time, 2 to 15 minutes or so) & I show I am short (under a quart or so), I do not add until checking again after an overnight sit.
That's my general practice when checking, I basically just follow consistency in procedure to obtain good readings, as I explain above.
