No I didnt fall off the wagon again, but I noticed after my last oil change the next morning I went out and checked it with the truck parked in the same spot and engine cold, The oil was 1/2 quart too high. This is the second time I noticed this after the truck sits for 3 or 4 days. I also noticed that the oil reeked of gas. I pulled 2 of my ngk plugs, and there was heavy "Gummy" junk on the electrodes.
About 2 weeks ago I got a p0450 code "Large Evap Leak", then this morning the truck didn't want to start. Got off work and tried it again, and after cranking for 15 seconds and flooring the peddle, I got it to start. I smelled a strong odor of gas coming from the tail pipe.
Could a bad in injector of Fuel Pressure Regulator be causing this? Some help is welcomed on this one. I'm totally stumped.
