kibatheloanwolf wrote:Oh s***....I have done 3 oil changes with out replacing it and now valve train #4 is tapping
No biggie, I dought that the little oil leak is making your valves get louder. The naps-z engines have adjustable rocker arms that you can set into spec again, yay! It says to set them with a hot engine at like .14, but I found it hard to keep the engine hot while completing the entire operation, so... I set them while the engine was cold, (about 72 degrees outside that day), at .09, and it turned out good that way. Oh yeah, the little copper rings for the drain plug are available at almost any auto parts store in packs of 3, about $3.50
P.S. If you haven't set valve clearence before, you will see that you should check each valve a few times because torquing the locknut can tweak it back out of spec. The directions are in the service manual.
