DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sun May 25, 2003 7:53 pm
Usually caused by going to the outside of the bolt hole when resealing the cover with RTV. If you're sure the cover doesn't need to be removed, here's what I would do: Undo the bolt and clean out the hole real well with Brakleen and Q-tips. Put a glob of RTV around the shank of the bolt just under the head. Put the bolt back in and torque it down, making sure the RTV completely fills the gap between the bolt and the cover. Clean up the squeeze out and let it cure for 24 hours.
