(((Leaking not at the part where it has a threaded hole, but the bottom part tip before that.)))
I was thinking could it be the cam-shaft oil ring gasket by the cams that is not sealing completely? I tried moving the ring and troque the cam-shaft towers n place and still doesn't work. But, before I even decide to go head and order a new ring seal are their any other part that you guys should recommend me to check first? I don't want to make a mistake by purchasing a new ring, then reinstalling it and have the same problem.
