Oil leaking from my Cover help!!!?
Dmnitsadean
Car: 90' Nissan 240 SX
well a new topic for me to discover...wow.....oil leaks were to begin well fuk... okay heres how it goes.... Okay the cover were the Timing chain is well its leaking from there.....my question is well i used that one wet gasket i forgot whats it called but fuk I dunno if we even did put it on right....well wat we did is this when we took off that cover because we had to get to the tensioners I had to change them...but this was bout 3 months ago....well we put it on the way it should go but should we have too off the whole head than put that on I dunno but it looks like its on right....I guess its leaking cuase its loose....and maybe because when i did a change oil I started using Sintetic.....seems lyke the oil was really light so I guess it seeps in the dippest wholes but yeh i dunno if this is bad but wat should I do now its only leaking from there the whole edges of that cover..." cover for waterpump etc.....Were the timing chain is located" well what should I do now? plz help thanx.....DeAn
BadMojo
Car: 2007 Mazdaspeed 3
No offense, man, but I can barely figure out what you're talking about. Short sentences and punctuation are good things. Also, a little spell checking might not hurt.
Anyway, I'm assuming you have the Dual Overhead Cam KA24DE engine. What year is your car?
It sounds like you have oil leaking from the upper half of the cover on the front of the engine. When you say it's leaking from the edges, do you mean up near the valve cover?
While synthetic oil will be thinner than an equally rated conventional oil, the leak wouldn't be caused by the oil you use. There are two rubber gaskets between the head and the valve cover, RTV used on the sides of the upper cover (running a bead on the inner side of the bolt holes, toward the engine) and then the head gasket extending out at the bottom between the upper and lower covers at the front of your engine.
If I had to guess, I'd say either a) your valve cover gasket got torn or is dried out OR b) you didn't get a good bead of RTV on the front upper cover when you did your tensioner.
Hope that helps, and let me know if any of the assumptions I made were incorrect.
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
I had oil leaking out underneath my valve cover...
What happened was I went crazy when I torqued the two front valve cover bolts and stripped the holes, so there was barely any seal there at all. Guess it wouldn't hurt to check those out too.
It was a quick fix with a Helicoil.
