JunseiMotors »
https://forums.nicoclub.com/junseimotors-u152104.html
Sat Jan 30, 2010 5:26 pm
Replace the oil seal on the oil cooler. Remove your oil filter, let the oil drain. Grab 2 small vise grips and pinch off the 2 small hose which lead up to the oil cooler so that coolant does not flow out. Remove hose clamps, push hoses off the way. Remove the oil mount/oil cooler bolt. I believe is a 21mm or 22mm. Once thats off, pull back the oil cooler, and replace the orange oil seal there. That should take care of the problem. If it continues to leak, replace the whole oil cooler assembly. The face will be warped. Happens often. Done that job many a times here at the dealership.
