Oil Leakage, Turbo Glowing RED HOT
silviaxspress
Car: everything
The pipe's metal tie couldn't hold the pipe together and popped off on Friday night. Found that motor oil was in the piping, but I don't know if there should be motor oil in that pipe.
Close up of the pipe, already fixed. Just reattached it.
You can see the Stainless steel line that is connected to the turbo, but unfortunatly, after Friday night, the steel line is now torns and motor oil bleeds out of the stainless steel line when I start the car. The turbo, on the top left started getting red beacuse it was so HOT, that it affected my master cylinder. You can see that there is some melted smuge. But I now it's replace and I have a cover for the master cylinder to prevent it from too much heat again.
Modified by silviaxspress at 3:32 AM 2/19/2005
